Duplicate footage effect
Vasco Dias
on May 17, 2017 at 2:45:58 pm
In this video (https://vimeo.com/200406141) there is one effect that i'm trying to identify and know how to do it.
For example at 5 seconds, and in all the video it uses that effect. It's like a ghost/clone/duplicate/glass effect.
Anyone know what it is? Or how i can acchive something like that without any effect?
Robert Olding
Re: Duplicate footage effect
on May 18, 2017 at 2:18:16 pm
Copy the footage you want to use and place it above the corresponding storyline. Choose the Transform tool from the Inspector and scale, or rotate, or shift the position of the copied footage in relation to the footage in the storyline. Then choose the Compositing tool from the Inspector and choose a blend mode such as Normal, or Overlay, or Soft Light. Then adjust the Opacity to your liking. To hide distracting visuals such as the edge of the frame, you will need to mask those portions of the copied footage.
Robert Olding
http://www.8streetstudio.com
Minneapolis, MN
Vasco Dias
on May 19, 2017 at 10:43:56 am
Hi! I've tried that but i couldn't achive the same look.
It's a little creepy :b it's not like a reflection but like a real ghost ihih ☺ There's any other way to do it?
John Rofrano
on May 19, 2017 at 12:25:44 pm
It looks like they may be using a mask because only the hand gestures are doubled. Look at the groom's face... it is crystal clear. So they are superimposing only part of the video which I assume is accomplished by masking out the rest. It sure looks to me like it's just zoomed with opacity lowered to almost nothing or perhaps composited with screen mode. It's definitely not a full frame overlay.
Don't forget that it might look a certain way because of the "content" of the video. The white cuff will composite very differently than a darker color would so your video might not achieve the same result because of the luminance of the content.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
