Damaged Library -
Scott Witthaus
Damaged Library -
on May 11, 2017 at 6:22:58 pm
Hey all -
Did the upgrade to 10.3.3 and all was going smooth, but one Library keeps being rejected as Damaged. When I open from a back up, that is supposedly "Damaged" too. Any ideas here? Working fine on 10.2.3.
Scott
Scott Witthaus
Owner, 1708 Inc./Editorial
Managing Partner, Low Country Creative LLC
Professor, VCU Brandcenter
Noah Kadner
Re: Damaged Library -
on May 11, 2017 at 8:29:11 pm
Unfortunately, that can happen with library bundles that were manually altered, and they would have to either be completed with 10.2.3 or migrated with library XML.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Scott Witthaus
on May 11, 2017 at 8:33:08 pm
Can you define what "manually altered" would be?
[Noah Kadner] "or migrated with library XML."
So export XML with 10.2.3 and imported into 10.3.3?
Scott Witthaus
Noah Kadner
on May 11, 2017 at 11:28:11 pm
Ie if you moved anything in or out of the Library package in the Finder. Or it became corrupted via a file transfer permissions change or just gremlins.
Noah
