Need a way to rapidly show 50+ images within 20-30 seconds
Jeff Swearingen
on May 10, 2017 at 4:16:49 am
Hello -- I can't put my finger on the term for this. But essentially I need to drop in a series of 50+ stills into an FCPX project and have them quickly cycle through around 0.5 sec each.
Any suggestions to make this efficient?
Jeff
Helgi Thor
Re: Need a way to rapidly show 50+ images within 20-30 seconds
on May 10, 2017 at 1:35:13 pm
Select all the stills in the browser, hit E to put them in the project, select all, hit ctrl-D, enter 15 (or 12 if it's a 24fps project) hit Enter.
Helgi Thor
Editor
Fortaleza
Brazil
Helgi Thor
on May 10, 2017 at 1:40:05 pm
And if you need to do this regularly you can change the default duration of stills in the preferences.
Helgi Thor
Editor
Fortaleza
Brazil
Jeff Swearingen
on May 12, 2017 at 11:09:39 am
Perfect. Thank you!
Eric Santiago
on May 15, 2017 at 5:40:20 pm
If your lazy place in a CC and use Speed controls.
Jeff Swearingen
on May 23, 2017 at 6:07:57 am
Thanks for the responses. Using Command-D and the duration was the easiest.
