Settings for sending video by WhatsApp
Chuska Esteban
on May 4, 2017 at 9:49:06 am
Hello!
I have a master in Final Cut Pro of 5 minutes in HD 1920 x 1080 Pro Res.
I have to send it by WhatsApp, so I would like to know which are the best settings to compress it in Final Cut or in Compressor.
Create a mp4 or m4v ? What sizes it´s the best for reproduction in a mobile phone?
Thank you very much
John Rofrano
Re: Settings for sending video by WhatsApp
on May 4, 2017 at 10:50:41 pm
I would use the Apple Devices 720p setting in FCP X or Apple Devices HD (Most Compatible) in Compressor. You certainly don't need anything larger than that for most mobile phones and even tablets. This will create an MPEG4 AVC/H.264 video file with AAC audio which should play nicely in WhatsApp.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Helgi Thor
on May 5, 2017 at 3:53:46 pm
I believe there is a 16MB limit for videos in whatsapp, so you'll need lower the bitrate a lot (unless they've increased it). Compressor gives you an estimated file size as you fiddle with the bitrate settings.
Helgi Thor
Editor
Fortaleza
Brazil
Chuska Esteban
on May 8, 2017 at 8:46:25 pm
Hello:
Thank you so much for your answers. I have use the setting Apple Devices HD (Most Compatible), with the size 960 x540 the bitrate was automatic, the size of the video was 150 Mb. Through AirDrop I sent it to my Iphone and then I sent it through Whatsapp. The final size was 50 Mb.
So it seems that the WhatsApp limit is 50 Mb and the size of the video received by whastApp it´s always of 848 x 480.
I wonder if I should change the initial size of the video, and about the bitrate, I lowered too much and I saw the pixels, I wonder which it´s the limit to see it properly.
Thank you again
John Rofrano
on May 14, 2017 at 12:12:31 pm
[Chuska Esteban] "I wonder if I should change the initial size of the video"
I would. This way you are in control of resizing the video and WhatsApp is only changing the bit-rate. That would give WhatsApp less to do (and less to mess up).
~jr
