Best way to contact Apple to request features and fix issues?
Matt Wilson
on May 2, 2017 at 3:50:16 pm
Does anyone know the best way to contact Apple to request features and fix issues?
(Apparently when using Audio keyframes for volume, other than original 2 fade handles, you can only get a S-curve. There's no choice for linear. So I want to request adding linear curve option.)
Matt
Doug Metz
Re: Best way to contact Apple to request features and fix issues?
on May 2, 2017 at 4:49:27 pm
From the Final Cut Pro menu (next to the ), select 'Provide Final Cut Pro Feedback...'
After reading your previous thread, I've made this request as well.
FWIW, if you really -need- to have a linear fade, you can blade the clip and apply an Audio-Only transition which provides the options.
Doug Metz
Anode
Matt Wilson
on May 2, 2017 at 7:38:33 pm
Thanks Doug. Will send the feedback to Apple today. Yeah the blade tool is an option, but if I end up using 3 or 4 keyframes in a clip, my clip might be cut up into multiple smaller clips, and since I'm sending to Audition, and then to Resolve, I didn't want my clips cut up like that.
Matt
Matt Wilson
on May 2, 2017 at 9:49:26 pm
Just read article - good advice/tips.
