Final Cut add colors to the clips itself?
Cagla Angel
on Apr 30, 2017 at 6:45:30 pm
Hello everyone,
Thanks for taking time to read my post.
I edited a movie on Final Cut Pro X, the real colors are quite flat, they shot it that way so we could easily add colors afterwards, although when I import them to Final Cut Pro they change color, it's like it adds colors to the clips itself. I checked the color options and it says it does not have any effects on clips.
I also exported the film just to see if it's still like that, and yes it lost that flat color. How do I fix this?
I attached some images for you to see the difference.
Thanks in advance!!
Michael Hancock
Re: Final Cut add colors to the clips itself?
on Apr 30, 2017 at 10:25:35 pm
Select your clips in your event, open the inspector, go to the Info tab, set it to "Settings", then change your log processing to None.
Michael Hancock
Editor
Cagla Angel
on Apr 30, 2017 at 10:59:57 pm
Thank you so much, I just did!!!
Best
