video stabilisation messing up sharpness
Mike Tyler
on Apr 30, 2017 at 4:24:27 pm
I was stabilising some footage with people (faces) in it and the whole video just looks bad and the faces blurry.
Is there a way to overcome this ?
How do you stabilise footage with faces in it ?
Noah Kadner
Re: video stabilisation messing up sharpness
on Apr 30, 2017 at 4:37:19 pm
Depends greatly on the degree of stabilization being added- it's designed to help mostly stable usable shots not turn handheld into tripod. Share an example shot for more advice.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Mike Tyler
on May 1, 2017 at 2:51:19 am
ok, so now I realised where the issue (probably) was..
There were a few frames where the face was out of focus.. normally, it was almost unnoticeable but with the stabilisation activated it was way worse..
Bret Williams
on May 1, 2017 at 11:38:28 am
Except for the stabilization mode specifically called "tripod." :)
_______________________________________________________________________
http://BretFX.com FCP X Plugins & Templates for Editors & Motion Graphics Artists
Noah Kadner
on May 2, 2017 at 3:35:33 am
It should be called wishful thinking... 😂
Noah
Bret Williams
on May 2, 2017 at 3:53:59 am
Worked for me just the other day with interesting results. Now you have a shot with the foreground object locked off solid, but the background is somehow magically moving around behind it!
Mike Tyler
on May 2, 2017 at 8:42:24 am
unfortunately, the video wasn't shot by me.. I was doing just the editing.
I was actually looking into buying a steady cam for moving shots.. not crazy expensive and pretty good results from what I've seen.
