Masking in Final Cut Pro X
Zade Cross
on Apr 20, 2017 at 7:42:50 pm
Hi Guys,
I wondered if you could help with the best way of going about this type of mask in final cut.
I would like to create 3 triangles, with 3 different videos playing. I have been able to create the mask but when I try and scale/position my footage, the mask is moved/resized instead of the footage. Is there a way I can do this, create the mask and then position my images within the mask?
Noah Kadner
Re: Masking in Final Cut Pro X
on Apr 20, 2017 at 11:44:36 pm
Probably with enough fiddling but to be honest- this is perfect for Motion.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Robin S. Kurz
on Apr 21, 2017 at 1:05:40 pm
The mask is attached to the video, so, yeah, it'll move with it. Which is why you would need to either move THE CLIP first THEN mask it, or move the clip and simply readjust/move the mask.
There's no easy solution that I can think of within FCP. That's what either Motion is for, where you can make your own template using drop zones, or 3rd party plugins that do a split screen effect. Of which there are many. E.g. mFrame: https://www.motionvfx.com/mplugs-96.html (check out the 19th template in the list).
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
