Exporting Audio Roles
Daniel Elder
on Apr 14, 2017 at 3:51:39 am
I figured out a way to fix my Audio Roles & Audio Configurations problem rather quickly, which is great! Now I have a question about exporting audio for my mixer. When I export my audio files, I will have my roles set up as Dialogue 1, 2, 3, 4, 5, 6 and then Boom 1, 2; so if I want to make sure each audio file is exported to my audio mixer, do I need them all to be activated (check mark selected) in my project timeline or will it export each Audio Stem regardless for mastering?
Dan
Daniel Elder
producer
http://www.elderproductions.com
Noah Kadner
Re: Exporting Audio Roles
on Apr 14, 2017 at 4:29:38 am
You have to export as QuickTime with Multitrack audio and then select which Roles go to which tracks. https://support.apple.com/kb/PH17904
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Daniel Elder
on Apr 14, 2017 at 5:53:53 am
Thank you Noah, that helps a lot!
Daniel Elder
producer
