Replace multiple drop zone content easily?
Tangier Clarke
on Apr 6, 2017 at 6:38:09 pm
I am using a text messaging plying from idustrialrevolution. The photo I am using in the plugin's drop zone in every instance of the plugin of the timeline needs to be replaced.
Is there a way to replace these at once rather than individually? I tried seeing if the file referenced by the drop zone would show up in the xml of the project so that I could just change the file reference, but it doesn't not show up there.
Any ideas on achieving this?
Bret Williams
Re: Replace multiple drop zone content easily?
on Apr 7, 2017 at 7:27:55 pm
If the photo referenced is in a compound clip, then just change the photo in the compound clip. Otherwise perhaps you can relink the photo you're referencing to a different photo. As long as it matches the same specs I think it should work.
_______________________________________________________________________
http://BretFX.com FCP X Plugins & Templates for Editors & Motion Graphics Artists
