timeline exports without audio
Stephan Scrofani
on Mar 30, 2017 at 8:14:58 pm
I'm having trouble figuring out why my timeline is exporting w.out audio. It's a simple edit, with 2 generators - a timecode layered over entire clip, and 2 seconds of color bars prior to the start of a filmed interaction.
When I remove the color bar generator, leaving just the clip with the timecode, it exports with both audio and video.
I ran into a similar problem on a different edit - that time, the clip was exporting fine without any generators added, but not exporting with audio when I had a timecode in.
Any thoughts on what is going on here?
Thank you,
Stephan
Noah Kadner
Re: timeline exports without audio
on Mar 31, 2017 at 12:21:02 am
To which formar are you trying to export?
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Stephan Scrofani
on Apr 4, 2017 at 9:44:56 pm
Hi Noah,
Thanks for your reply.
I'm exporting a quicktime movie (master file settings) - codec is Apple ProRes 422. Do you need any more info?
Stephan
