Hide (or toggle off) the Active Clip Frame?
Ernie Munick
on Mar 30, 2017 at 4:50:06 pm
Is there a way to hide or toggle off the frame around the active clip in the viewer, so I'm just seeing the clip and can move the clip around, without seeing the frame (wrong word, I think) around it?
Jeff Kirkland
Re: Hide (or toggle off) the Active Clip Frame?
on Mar 30, 2017 at 9:15:59 pm
Not if you are manipulating it directly with th\e mouse but you can move it by scrubbing the coordinates in the info panel without activating the frame. That's how I move things 90% of the time.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Ernie Munick
on Mar 30, 2017 at 10:29:55 pm
Yeah, but that frame covers a bit of the edge, which is why I'd rather make the frame disappear. And then, as you said, use the parameters instead of the mouse.
Thank you!
Bret Williams
on Apr 1, 2017 at 12:05:15 am
There won't be a frame if you use the inspector while in regular arrow (A)mode.
_______________________________________________________________________
http://BretFX.com FCP X Plugins & Templates for Editors & Motion Graphics Artists
