Changing angles gives a slight click/pop
Sam Clarke
on Feb 14, 2017 at 9:35:20 pm
Hey guys,
I'm slightly pulling my hair out over this. I only have one audio track active but switching between 3 angles. it doesn't happen every time, but there's an audible pop. and as i'm recording acoustic music it's really obvious.
i have no effects on as i thought that might be the problem.
Any ideas?
Many thanks
Noah Kadner
Re: Changing angles gives a slight click/pop
on Feb 14, 2017 at 10:40:03 pm
Are you switching video only?
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Sam Clarke
on Feb 14, 2017 at 10:45:38 pm
Yep. I only have one audio angle selected and just switched the video. It doesn't do it on every angle change which is puzzling
Sam Clarke
on Feb 14, 2017 at 11:20:43 pm
The only thing i can think of is the audio from one of the angle (which is muted) is 48kHZ and the other are 44.1, maybe that screwed something up
Noah Kadner
on Feb 14, 2017 at 11:55:27 pm
Make sure the audio you're using matching the sequence audio frame rate. Usually when you hear a pop during editing that's sampling rate conversion errors. They shouldn't be on exports but then again you shouldn't hear them while editing either if all is well.
Noah
