Convert AVCHD
David Mayer
Convert AVCHD
on Feb 14, 2017 at 5:44:24 pm
ClipWrap2 is not working to convert slo motion AVCHD files from Sony FS-5 to ProRes 422.
How do I convert the files for FCPX?
iMac (Retina 5K, 27 inch, Late 2015)
4 GHz Intel Core i7
16 GB 1867 MHz DDR3
OS X 10.11.6
Final Cut Pro X (10.2.3)
Canon C100
Pioneer BD-RW BDR-206D (Blu-ray)
David Mayer
Re: Convert AVCHD
on Feb 15, 2017 at 12:39:25 pm
will try that - thanks, Noah
4 GHz Intel Core i7
16 GB 1867 MHz DDR3
OS X 10.11.6
Canon C100
Jeff Kirkland
Re: Convert AVCHD
on Feb 14, 2017 at 8:09:01 pm
Clipwrap is fairly old. Have you tried its big brother, EditReady for the conversion?
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
David Mayer
Re: Convert AVCHD
on Feb 15, 2017 at 12:40:51 pm
yes editReady did the trick - thanks
4 GHz Intel Core i7
16 GB 1867 MHz DDR3
OS X 10.11.6
Canon C100
Mike Fitzsimmons
Re: Convert AVCHD
on Feb 15, 2017 at 2:57:30 am
I import AVCHD file from my Z150 directly into FCPX and tell it to create optimized media. You might need to update to newer FCPX if your version is too old.
Mike
'Burbs of Detroit
David Mayer
Re: Convert AVCHD
on Feb 15, 2017 at 12:41:51 pm
Mike - thanks for the note - turns out we are 5 miles away.
Wonder if we've met?...
4 GHz Intel Core i7
16 GB 1867 MHz DDR3
OS X 10.11.6
Canon C100
Mike Fitzsimmons
Re: Convert AVCHD
on Feb 15, 2017 at 5:37:37 pm
Probably! Small world... Where are you?
Did you ever try importing directly into FCPX? Should work, if that's where you'll edit, saves a step or two.
Mike
'Burbs of Detroit
