FCP X info Metadata
John Treffer
FCP X info Metadata
on Jan 26, 2017 at 10:31:04 pm
Maybe it is obvious, but I can not find it:
How do you NOT get the "Share metadata" in a file exported from FCP X.
When I export/share from FCP X the default 'Info' tab has lots of fields for Metadata. Lots of them filled out with my name, the Project name and the year. They are fields like: creator, screenwriter, producer etc.
They are wrong, I am no screenwriter, never been, never will be. I think.
So I delete the fields, export the file, send it to a client.
And when I press command-I in the finder I find out the movie contains the Metadata I thought I deleted.
Is there a way not to have FCP X create all this (ridiculous) metadata in my files?
And if not, is there an easy way to delete this metadata?
Thanks for any help here.
John
Noah Kadner
Re: FCP X info Metadata
on Jan 27, 2017 at 12:26:55 am
You mean the blank fields? Nope they are standard placeholders.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
John Treffer
on Jan 27, 2017 at 1:35:14 pm
I discovered an okay workaround: replacing the filled out fields with a space instead of deleting them.
I still hope there will come a solution to not having to do this for every export, but it is better than fiddling with metahoot or the terminal.
Noah Kadner
on Jan 27, 2017 at 2:38:38 pm
On the other hand it's unlikely your client will ever find that metadata or care.
Noah
John Treffer
on Jan 27, 2017 at 3:46:59 pm
I actually had a complaint once by a client about it who had to pass the files on to an archive.
I am convinced some other, more technical clients, will see the Metadata as well.
Probably they will not really care.
But it is not very professional and I dislike that.
