Replace with Gap Multicam - FCPX 10.3.2 (Not possible)
Stanley Sousa
on Jan 25, 2017 at 3:22:19 pm
Guys, I can not use "replace with gap" in fcpx 10.3.2 in multicam.
This was possible in multicam in 10.2.3, and I used a lot to cut my marriages.
In 10.2.3 I used "in" "out" to select, and cut with "Backspace". In this way there was a space between the two clips, maintaining synchrony.
Follow the video below comparing this feature in both versions.
Andy Neil
Re: Replace with Gap Multicam - FCPX 10.3.2 (Not possible)
on Jan 25, 2017 at 7:10:05 pm
I was able to confirm your problem. I hadn't used that feature before so I didn't realize it'd been changed. I think you use the feedback menu to explain that both ripple and replace with gap should be possible in multicam.
However, as a workaround, you can blade sections, select and delete. this will leave a gap in the multiclip. Also, the roll tool works so you can peel back clip edges and leave a gap as well.
Andy
https://plus.google.com/u/0/107277729326633563425/videos
Stanley Sousa
on Jan 25, 2017 at 10:48:57 pm
Thank you Andy.
Thanks for confirming that this is a bug.
As you said, I am using the blade tool to cut, but I get higher speed using "in out" + Backspace.
I'm sorry for English. I'm in Brazil
Mike Fitzsimmons
on Jan 26, 2017 at 5:17:37 pm
Hey... If I'm understanding the issue correctly, In/Out + FORWARD DELETE (or SHIFT DELETE) will leave the gap.
Hope this solves it...
Mike
'Burbs of Detroit
Andy Neil
on Jan 26, 2017 at 5:21:58 pm
[Mike Fitzsimmons] "Hey... If I'm understanding the issue correctly, In/Out + FORWARD DELETE (or SHIFT DELETE) will leave the gap.
I've tried this Mike. It doesn't work. I think this is because gap footage is a construct that can be selected (and added to a timeline via the replace with gap shortcut), but there is no "gap" footage in a multiclip. This seems to be a change from the previous version and I'm not really sure the point of it.
Andy
