Multicam Audio Editing is A Major Pain
Ken Bennett
on Jan 1, 2017 at 12:52:59 am
I have a 2-camera ceremony where cam1 has 2 audio sources and cam2's audio for syncing only. So after I do my multicam edit I have my Multicam clip and my Project.
I need to edit each audio input from cam1 for balance and tweaking and switching each one off where necessary. I can not Detach or Expand my audio in the Multicam clip. In the Project I can, but there are a 100 cuts between each camera forcing me to edit each cut's audio separately. This of course would take hours. There has to be a much fast way to edit audio in Multicam shoots.
Suggestions? Tutorials?
Thanks.
Ken Bennett
Video Adventures
Capturing Your Life's Adventures!
Noah Kadner
Re: Multicam Audio Editing is A Major Pain
on Jan 1, 2017 at 7:54:48 am
Not sure exactly what you mean- but you can switch video only so that the audio track is continuous across cuts which should make things much easier if the audio track is without issues.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Jeff Kirkland
on Jan 1, 2017 at 10:00:51 pm
Select all the multicam cuts in the project and make them a compound clip. Show audio lanes and you will have all your audio reassembled into continuous tracks.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
