How to select next or previous clip in timeline by shortcuts?
Wu Zhengjiang
on Dec 30, 2016 at 4:36:49 am
I know ; and ' jump to next and previous clip. But these shortcuts don't select the clips. When doing color correction, it is very handy if I can select next clip by shortcuts, just like in DaVinci Resolve.
Is there anyway to do that?
Noah Kadner
Re: How to select next or previous clip in timeline by shortcuts?
on Dec 30, 2016 at 6:14:15 am
If you have a color board open in the inspector and deselect all clips it will then reflect the clip currently under the playhead. So then jumping to next clip will automatically show that clip's color board.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Wu Zhengjiang
on Dec 30, 2016 at 1:28:15 pm
Thanks, man! DESELECT all the clips, that is the key. When I was trying, I always already selected one.
You save my day, thanks again!
Jeremy Garchow
on Dec 30, 2016 at 5:45:13 pm
You can also explore the Select Above and Select Below shortcuts that will select clips above or below your current selection. Command up and command down are the default shortcuts.
Also, if a playhead is over a clip you want, but eh clip is not selected, simply hit 'c' which will select the clip in the primary storyline, and if you need to select above it, then hit command up.
Jeremy
Wu Zhengjiang
on Dec 31, 2016 at 1:34:48 am
Thanks! That is very helpful.
