Multicam audio level is not the same on the final edit project - how to get 1:1 level throughout
Sam Lee
on Dec 29, 2016 at 9:56:30 pm
Is there any reduction in audio level from the multicam sequence to the final project? In other words, will it be a 1:1? So far I noticed it's not 100% the same. Instead, ther is a small reduction in the final level.
Noah Kadner
Re: Multicam audio level is not the same on the final edit project - how to get 1:1 level throughout
on Dec 29, 2016 at 11:41:51 pm
This can be due to a variety of factors- for example you may have multiple angles with their audio active in the Angle Editor whereas your final timeline only has a single audio angle active at a time. More info needed.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Sam Lee
on Dec 30, 2016 at 1:06:03 am
My angle editor has 3 angles: A cam, B cam, and sound recorder. In the angle editor, I only chose the sound recorder as the active audio angle. If I do this, then only the sound recorder angle gets carried over to the final project right?
If I have clicked on A angle and sound recorder angles (via the purple speaker icons), will both of these angles get carried over to the final project too?
Noah Kadner
on Dec 30, 2016 at 6:10:09 am
You can only have one audio angle active in a project timeline at a time. Control click on a multicam clip to see which audio angle is currently active.
Noah
