many stills in project
Craig Alan
on Dec 12, 2016 at 6:58:12 pm
I am doing a project in which I am exporting edited stills from Aperture. These will be a large portion of the visuals for this project. What is the best workflow for doing this? What size, codec, organization etc. I did this back in the FCP legacy days and there were specific recommended codec and size. I've heard that X handles this much better than legacy. I'll store them in the media folder in the finder as "stills".
The video portion of the project will be from a Panasonic P2 camera
system mode: 1080-59.94i
rec format: AVC-I 100/30PN
CAMERA MODE 30P
Not sure what the latest of FCP X (version 3) is doing with the footage since it seems to take some extra time transcoding.
But basically this is a 1080 30P timeline.
The stills were taken as raw images Full-Frame about 20MP CMOS, 36 x 24 mm
a combination of portrait and landscape was used and I plan to use a black fill and for the most part the image that was captured not cropped (though I might change that given the result in FC.
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
Jeff Kirkland
Re: many stills in project
on Dec 12, 2016 at 7:38:51 pm
FCPX wilmdefinitely slow down if the images are too large so the close toy can get them to your final resolution the better depending on how much you might want to crop/zoom in. I can't say I've done projects that have used more than 20-30 images but I usually just make the narrowest dimension 2160px and go from there. Haven't had any issues with that.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Craig Alan
on Dec 12, 2016 at 7:57:55 pm
what codec? I plan to set the aspect ratio before importing if possible. I don't plan to zoom or crop in FC. In aperture the crop tool gives you the aspect ratio so I will pre crop it. I think I can also set a black crop to fill but haven't tried it. Though it can be done in FC as well.
Noah Kadner
on Dec 13, 2016 at 3:38:48 pm
PNG is typically a safe bet.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Craig Alan
on Dec 15, 2016 at 2:09:54 am
thanks
Doug Suiter
on Dec 14, 2016 at 1:41:42 am
You might want to take a few minutes to watch this - it's a tutorial I made a few years ago and will give you an idea of the sort of performance that you can expect.
Note that although the stills are jpeg and that they are not reduced in size at all (around 5k x 3k pixels)
I'll be updating the for 10.3 shortly, but principle is the same.
DOUG SUITER: FCPTalent
Find Production and Post Production Talent, Free.
web: http://www.fcptalent.com
twitter: @FCPTalent
Keith Mullin
on Dec 14, 2016 at 3:26:11 pm
FCP X can handle just about any format of still image you can throw at it. There is no "codec" to worry about really. I did a stop animation project that I edited in FCP X 10.2 with thousands of still images, it ran slowly after reaching a certain point, but seriously that was thousands and thousands of individual JPEG's.
Craig Alan
on Dec 15, 2016 at 2:09:15 am
mine might run in the 1000s. What was the resolution of your still exports and/or import from still camera card to FCP X?
Large stills used to really muck up legacy.
Keith Mullin
on Dec 15, 2016 at 2:47:08 pm
The workflow I used (which I would probably alter if I did another stop motion), was to capture 18 megapixel RAW images from a Canon T3i through Dragonframe. I then brought those images into Lightroom for color etc. I then exported them all out to JPEG and imported them into FCPX. I tried doing it with TIFF images instead, but the files were just too massive to work with. I never reduced the resolution of the images, and I ended up with a 3:59:00 animation at 24p, or roughly 5760 individual still images in sequence.
Craig Alan
on Dec 16, 2016 at 2:58:08 am
[Keith Mullin] "which I would probably alter if I did another stop motion"
what would be your new work flow?
but thanks for the details. becoming confident that this will be pretty painless.
Roger Poole
on Dec 16, 2016 at 1:24:40 pm
Jpeg is a comressed format and although all camera's record stills in this format to save space on the card it is not a delivery format and is lossy. If you take a jpeg and alter it in any way then re-save as jpeg, the whole thing gets re-compressed and you loose image quality. It's far better to save as a tiff or png, both of which are uncompressed formats and also have the advantage of being able to carry tranparency - or alpha, if required. Older versions of FCP didn't like jpegs, and for good reason. Being a compressed format FCP has to uncompress them to play in the timeline, most often resulting in a crash because of the huge processing overhead required. Although FCPX and Premiere can handle jpegs better jpeg's still require a lot of processing power. I think it far better, and quicker, to deal with stills outside of the edit, in Photoshop or whatever, for resising etc then saving as tiff or png. The size of your images should match those of your sequence dimensions, i.e. 1920x1080 @72ppi. If you plan on doing pan and scan you can double the resolution to 144 or 150ppi. This will allow you to push in on the image without losing resolution and image quality. Size matters. Pixels are a fixed size. a 1920x1080 frame size is natively 26x15 inches regardless of the tv screen dimensions, the bigger the screen the bigger the pixels are displayed. Most point and shoot still cameras record images that are at least 4ft wide in pixel dimesions, which in this example means that 4ft has to be crammed into 26inches. It's excess baggage and a much bigger file size than required for video sequence. If not dealt with beforehand will result in massive project size if lot's of stills are used in the sequence.
Keith Mullin
on Dec 16, 2016 at 3:15:28 pm
I would probably skip the trip into Lightroom. The Dragonframe software has a lot of export options that would have been plenty good enough for doing color and adjustments directly in FCPX, but 2 years ago I didn't know as much as I do now about color depth and codecs.
