video effects with masks fail during cross-dissolves
Rob Clev
on Dec 10, 2016 at 11:45:54 pm
I have an effect with a mask on a multicam clip on the timeline which hides a small portion of the frame. All is well without any transitions but when I add cross-dissolve transitions to other 'angles' in the multicam clip the effect is not applied to the video during the dissolve. Anyone know of a fix for this. FCPX 10.3.1.
Noah Kadner
Re: video effects with masks fail during cross-dissolves
on Dec 11, 2016 at 7:10:19 am
You're applying the transitions within the angle editor or on a project timeline? Screenshot would be helpful.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Rob Clev
on Dec 13, 2016 at 2:38:20 am
The transition is on the project timeline.
I tried applying the effect to the clip on the timeline and when that didn't work I tried applying it in the angle editor. That didn't work either. I then tried applying the effect and making it a compound clip. That didn't work either.
I finally gave up in frustration and used the censor filter to hide the portion of the frame. The result was not as elegant but at least it works through a transition.
A J Dimaculangan
on Dec 13, 2016 at 2:24:24 am
I don't know if this is related but we've noticed that the order of the effects stacked in the info window can effect the results. By shifting the order that the masking effect lies in that stack will affect the render.
By having the mask being added last has given us the best result.
Hope this helps,
AJD
Rob Clev
on Dec 13, 2016 at 2:39:50 am
Thanks for your reply. I could not get this to work at all. See my comment above.
