codec change not working
Alina Mnatsakanian
on Dec 9, 2016 at 10:12:05 am
I'm trying to change the codec from PAL to HDV 1080i60 and it's not working and it gives me a out of memory message.
What is the problem?
Alina
John Fishback
Re: codec change not working
on Dec 16, 2016 at 8:12:39 pm
Not sure what you're asking. PAL like NTSC is a television system, not a codec. You'd find HDV in both PAL & NTSC. Do you want to end up in PAL or NTSC (1080i60 implies NTSC)? And if you want to end up with an HDV 1080i60 what codec is the original (DV, DV50, etc.)? You might consider doing the transcode in Compressor.
