Audio-only ripple edit in 10.3?
Anton Antokhin
on Dec 8, 2016 at 8:10:29 am
I select a range on an video clip, hit delete, and ripple cuts it.
I do the same on the audio-only clip and it disables the portion that was selected.
Is there a way to ripple-delete audio-only using the range tool? What I am trying to do is to cut out a section in the middle of the music and have the remainder collapse together.
I know I can use the blade to make two edits, but hoping there's a better (faster) way.
Jeremy Garchow
Re: Audio-only ripple edit in 10.3?
on Dec 8, 2016 at 5:17:37 pm
[Anton Antokhin] "I select a range on an video clip, hit delete, and ripple cuts it.
Yes there is. I don't know why this changed in 10.3, but it did.
You have to map a kb shortcut to 'Delete Selection Only':
Then select a range, hit this new kb shortcut, and it works like the old delete.
Anton Antokhin
on Dec 8, 2016 at 5:55:53 pm
👍 works great, thank you!
