4K Material on 1080p Timeline comes in wrong to DaVinci
Sascha Engel
on Dec 6, 2016 at 5:10:45 pm
Hi Everybody,
Following problem: I have 4K Material (Apple ProRes HQ) from the Odyssey recorder.
It's performance registration.
In FCPX 10.2.3. I edited it into a 1080p TL so I could create an edit through re sizing.
Then I created an XML, and when going to DaVinci it creates a problem: I drag all my material to the media pool, then I imoprt the AAF from X,
and in the import window, I check the box of "use sizing information".
All clips are connected correctly, and to the zoomed clips, a resizing happened, but the position on the x,y scale if wrong.
How can you assure the AAF comes in interpreting the size infos correctly?
Thanx for a heads up on this one.
Greetings,
Sascha
Sascha Engel
KINO KITCHEN Studio
http://www.kinokitchen.co.il
http://www.youtube.com/taikang
Sascha Engel
Re: 4K Material on 1080p Timeline comes in wrong to DaVinci
on Dec 6, 2016 at 5:25:57 pm
I found the reason.
Maybe helpful to others: If you set in FCPX the Spatial conform to NONE and adjust Scale and Position it comes n wrong.
Your Spatial Conform has to be set to "FIT" in order to be read correctly by DaVinci.
Greetings,
Sascha
Sascha Engel
KINO KITCHEN Studio
