How do you cut the master by referring to a timecode list without the timecode being burned into the picture?
Tim Wilde
on Nov 23, 2016 at 5:15:25 am
I gave my friend a copy of the raw footage of her event with timecode burned in so she could pick the parts she wants me to string together into a simple edit. I added the timecode window in Compressor.
Now I'm sitting here realizing that once I chop out the first segment the remaining material in the timeline will slide forward, causing her timecode notes to be off. It occurs to me that before editing I could add a continuous title consisting of timecode, which I would somehow cut along with the actual video, but surely there's a better way.
Noah Kadner
Re: How do you cut the master by referring to a timecode list without the timecode being burned into the picture?
on Nov 23, 2016 at 5:31:02 am
Just reimport and then overcut her burned in version edits with the matching raw footage.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Jeff Kirkland
on Nov 23, 2016 at 6:03:39 am
I usually do this by putting the timeline and the timecode generator in a compound clip. The timecode overlay will stay in place as I cut the compound clip. Once done I just go into he compound clip and delete or disable the timecode.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland
Oliver Peters
on Nov 23, 2016 at 1:22:07 pm
You can also work in reverse order, doing the last notes first and so on.
Oliver
Orlando, FL
http://www.oliverpeters.com
Andreas Kiel
on Nov 23, 2016 at 2:03:24 pm
You can work like Oliver suggested or replace the uneeded parts by a gap.
- Andreas
Spherico
http://www.spherico.com/filmtools
"He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee." - Friedrich Nietzsche, Beyond Good and Evil
Michael Sanders
on Nov 23, 2016 at 10:25:02 pm
Apologies Oliver - I hadn't seen your reply!
Michael Sanders
London Based DP/Editor
Oliver Peters
on Nov 24, 2016 at 4:10:51 pm
Not a problem. It's quite alright.
Oliver
Orlando, FL
Michael Sanders
on Nov 23, 2016 at 10:24:05 pm
Start from the end and cut backwards.
Michael Sanders
Jeff Kirkland
on Nov 23, 2016 at 10:40:40 pm
With my compound clip method, you can turn the timecode overlay on/off to check your cuts (useful when the client says you cut in the wrong place) and you can cut from the start or the end of the clip - although I almost always start from the end and work backwards.
