Sequences Settings for Blu-ray Share
David Mayer
on Nov 4, 2016 at 6:45:12 pm
My Share to Blu-ray keeps stopping at 66%.
So I exported my project as a ProRes 422, Linear PCM file
and tried sharing that as a new Project to Blu-ray, instead.
For that one, my sequence settings are:
1080i HD
1920 x 1080
29.97i
Stereo 48kHz
Should I try different sequence settings or do I need to
trouble shoot the problem elsewhere?
iMac (Retina 5K, 27 inch, Late 2015)
4 GHz Intel Core i7
16 GB 1867 MHz DDR3
OS X 10.11.6
Final Cut Pro X (10.2.3)
Canon C100
Mark Suszko
Re: Sequences Settings for Blu-ray Share
on Nov 4, 2016 at 7:42:42 pm
Are you saving it to the hard drive, then burning it using Compressor, or burning straight to BD-ROM? I have a devil of a time making my BD-Rom dubs, seems like mine poop out at around the 60 percent mark as well. I have to take steps to make sure there is enough free space in the imac and the RAID to contain the image, pre-burn, and that the imac doesn't change the targeted burner or drive. Even when it works, it can take all day to make two dubs this way.
Lori Murphy
on Nov 5, 2016 at 3:27:52 am
I'm having the same issue. It's maddening! Trying to burn for a client deadline. Would love a solution!
Mark Suszko
on Nov 5, 2016 at 5:06:23 am
Try rendering to the hard drive first, then burning a disk image.
