Files split by camera
Mandy Leonardo
on Nov 1, 2016 at 4:57:03 pm
Using a canon xa30 and it splits the files at 2G. When I import into Final Cut Pro and piece them together on the timeline, there is a slight blip in audio. Are there any ways around this?
Craig Seeman
Re: Files split by camera
on Nov 1, 2016 at 7:26:23 pm
You shouldn't have to piece them together unless you broke the folder structure. Import from the parent folder created in the camera.
First step would be to create Camera Archive from the camera card.
Next you'd import from the Camera Archive.
If you've pulled the media files out of the folder structure, the metadata that joins them is gone.
