Overwrite edit on clip in secondary storyline
David Mathis
on Oct 29, 2016 at 9:18:18 pm
As much as I love FCPX there are a few things that really irritate me. One of them is trying to replace a clip in a secondary storyline. I want to set in and out points on the clip I want overwrite only to disover they migrate to the primary storyline. This is not what I want! I know you click on the shelf of the secondary storyline but I want to set the points on the clip itself not the one in the browser. Is there something I am missing or should I switch to something else?
Jeremy Garchow
Re: Overwrite edit on clip in secondary storyline
on Oct 29, 2016 at 9:48:51 pm
Select the clip you want to replace in the timeline, then set an in point on the incoming clip in the browser, and option-r to replace from start.
David Mathis
on Oct 29, 2016 at 9:55:48 pm
I also found the range tool works as well. I need to stop pushing the button to see what happens next. LOL
Jeremy Garchow
on Oct 29, 2016 at 10:07:11 pm
That was going to be my next suggestion, but the select and replace from start is faster for me.
