Moire in Sony XAVC footage from A7sII in FCPX but not when played back from camera to a monitor
David Wright
on Oct 11, 2016 at 11:45:27 pm
Just testing out a Sony A7sII in 4k and when I play back the footage directly from the camera to an HD TV, looks great. When it is loaded in FCPX, getting troubling moire issues...
Any suggestions why the footage played back from the card, through the camera and into a TV is fine, but not when loaded into FCPX? Playing back at full quality on a friend's high end edit system, so there should not be an issue. We regularly play RED footage through the same computer without an issue.
David
Jeremy Garchow
Re: Moire in Sony XAVC footage from A7sII in FCPX but not when played back from camera to a monitor
on Oct 12, 2016 at 4:42:24 am
This is in the viewer? Set the Viewer to 100% res, and make sure your playback is set to "higher quality". The picture should be just fine. The moire is in a low res downscale for the viewer playback.
