Computer trapped in 2010...
Marisha Camp
on Oct 7, 2016 at 6:22:38 pm
I have an older computer (which can only support USB 2 and Firewire.) And I need to edit down a huge amount of video, much of which is stored on external harddrives that only use USB. Is it possible to work efficiently using proxy files that would all be on one firewire drive while the source files are on USB or do I need to have everything connected via Firewire? Thank you so much!
Noah Kadner
Re: Computer trapped in 2010...
on Oct 7, 2016 at 7:24:58 pm
It's going to take a long time to read all of the USB 2 into Proxies but then sure. My suggestion would be to move the files onto a FW800 drive asap to avoid constant pain.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Tim Jones
on Oct 8, 2016 at 7:08:06 am
Are there no PCIe slots in the system (you don't say what it is)? If there are, try a HighPoint RocketRAID 2722 and a 4 drive SAS enclosure. You could hit almost 500MB/sec if you can so that.
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.tolisgroup.com
BRU ... because it's the RESTORE that matters!
Noah Kadner
on Oct 8, 2016 at 3:01:12 pm
Or a newer Mac...
Noah
Claude Lyneis
on Oct 8, 2016 at 5:03:27 pm
A quick look on the web showed that an external 2 TB G-tech drive with FW800 is about $200. (There are probably more choices) If you transfer your video onto that, it should give you a big boost in editing speed since FW800 is much faster than USB2.
Patrick Donegan
on Oct 17, 2016 at 4:53:51 am
If you are editing in FCP 7, there would be lots of "frame dropped during playback" from the USB 2 drives.
Does FCP X have that same error available?
FCP X 10.2.3 - user since FCP 1.25
iMac mid 2011, MBA mid 2012
iPhone 4
HVX-200, Shure wireless mic
Miller Solo tripod
Advanta-Jib
Steve Connor
on Oct 17, 2016 at 6:13:05 pm
Are the drives USB2 or USB 3? You can add a USB 3 Card very cheaply to an old Mac Pro and it makes it much faster.
