Library location
Oliver Peters
Library location
on Oct 5, 2016 at 12:03:23 am
What's the consensus on a system with a "trash can" Mac Pro and a Thunderbolt Pegasus array? Where to put the FCPX Library files - on the internal drive or on the array? With older Mac Pro tower set-ups, I usually split it, putting the Library on the internal drive and the media on the external. But with a faster array, is that still necessary?
- Oliver
Orlando, FL
http://www.oliverpeters.com
Noah Kadner
Re: Library location
on Oct 5, 2016 at 12:26:38 am
Depends on the media you're working with- that will require the speed more than the Library itself if it's high bandwidth. These days I put my Libraries anywhere but the system drive.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Oliver Peters
on Oct 5, 2016 at 12:32:48 am
[Noah Kadner] "Depends on the media you're working with"
HD and 4K. ProRes or other media (from A7, C300 MkII), etc. So, media will always be on the array.
- Oliver
Orlando, FL
Noah Kadner
on Oct 5, 2016 at 1:25:50 am
As they say YMMV but assuming you will be the only editor I'd just go Library and Media on the same drive. At this point it's streamlined enough as a container it won't gain much being on the system HD.
Noah
Warren Eig
on Oct 5, 2016 at 4:31:43 pm
I tend to put the libraries in a FCP Doc folder on the RAID. I have prefs set to leave media in place, but that being said, the Library file bloats pretty quickly with cache files, render files, etc. Fast RAID, no slowdown.
Warren Eig
O 310-470-0905
email: info@babyboompictures.com
website: http://www.BabyBoomPictures.com
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
