Logic Pro X and MXF
Wu Zhengjiang
Logic Pro X and MXF
on Sep 29, 2016 at 5:21:22 am
I exported a fcpxml file from FCPX, then imported it into Logic Pro X. All the audio from mxf clips were lost, which were shot by Sony FS5. But all the audio from other cameras (Sony A7Rii and a Canon 5D) were OK.
Is there anyway to solve this problem?
Darren Roark
Re: Logic Pro X and MXF
on Sep 29, 2016 at 7:10:51 am
Have you tried running it through X2Pro?
Wu Zhengjiang
on Sep 30, 2016 at 3:34:25 am
Wow, the price is little overwhelming. Is that the only way? I mean most time I can do all the audio processing in FCPX. I don't know if I should invest a software just for converting.
Jeremy Garchow
on Sep 30, 2016 at 10:24:14 pm
[Wu Zhengjiang] "I don't know if I should invest a software just for converting."
Because Logic can't understand the MXF files, but it will understand the AAF file created by X2Pro.
Wu Zhengjiang
on Oct 9, 2016 at 3:37:39 am
Thanks for the replies. I'll check it out.
