Creating DNX36 using Compressor 4.2.2
Frederico Cengarle
on Sep 26, 2016 at 12:37:21 pm
sorry if I'm not quite ion the right forum but I couldn't seem to be able to find a Compressor forum.
I was wondering if anyone had encountered this issue and found a solution. I've just upgraded my Apple compressor to v 4.2.2 and since then, I seem to have an issue creating Avid DNX36 files. When I go through Compressor, the result doesn't give me the right bit rate (it give me a bitrate of 175 mbps instead of the 36 expected). Now, if I try to create it in Quicktime Player directly everything works fine, the issue seem to be localized with Compressor v 4.2.2
Fred
