How to fix Audio - MONO - Final Cut X
Stephan Scrofani
on Sep 20, 2016 at 8:57:07 pm
I have a filmed Skype interview, split screen style. The problem is the audio from one person is too low and audio of the other person is overblown.
Unfortunately, I don't have one person on each channel.
Is there any way, other than manually key framing one person to an appropriate volume, that I can fix the discrepancy between the audio for each person?
Thank you in advance for your help,
Steph
Paul Figgiani
Re: How to fix Audio - MONO - Final Cut X
on Sep 20, 2016 at 10:40:46 pm
Try the Adaptive Leveler in Auphonic. (Desktop app. or the Web Service). You'll need to process the audio outside of FCPX. Then re-import.
https://auphonic.com
-paul.
Stephan Scrofani
on Sep 22, 2016 at 9:05:36 pm
Thank you! I'll try this
Kannan Raghavan
on Sep 20, 2016 at 11:40:22 pm
Try using a compressor. It should fix the problem like this in most cases.
Kannan Raghavan
The Big Toad Films Pte. Ltd.
Stephan Scrofani
on Sep 22, 2016 at 9:06:16 pm
Thank you, forgot that helps
Joe Marler
on Sep 21, 2016 at 12:36:43 pm
[Stephan Scrofani] "Is there any way, other than manually key framing one person to an appropriate volume"
Here is a MacBreak Studio on using the compressor that's built into FCPX:
Everyone probably knows this but you can also drag the range select (R key = range select mode) horizontally over the clip then drag that audio range up and down and it will adjust that region, putting a head/tail transition on the adjusted range.
Stephan Scrofani
on Sep 22, 2016 at 9:07:16 pm
Great, thanks, really helpful!
