Can I keyframe and increase over time a color correction?
Noam Osband
on Aug 18, 2016 at 5:00:07 pm
I filmed an interview using natural light and the clouds occasionally got in the way so I need to boost the exposure of some of the levels. That said, it happens gradually and I dont want to give my client a video where the color suddenly jumps.
Any way to keyframe a color correction so I have it come and go gradually? If I can't do this with FCP X, can I do this with Color Finale? I was thinking of getting it anyways and this might put me over the edge.
thanks!
Bret Williams
Re: Can I keyframe and increase over time a color correction?
on Aug 18, 2016 at 5:19:08 pm
Can't do it natively with X. Best you can do with the color board is blade the clip, have two different settings on each clip, and dissolve between them.
_______________________________________________________________________
http://BretFX.com Plugins & Templates for FCP X Editors & Motion Graphics Artists
Noam Osband
on Aug 18, 2016 at 5:20:41 pm
Any plugins that will let me do this?
Fedor von Hengstenberg
on Aug 19, 2016 at 1:11:53 pm
Probably the easiest way to achieve what you want is to place a copy of the clip on top of the original as a connected clip, then do your grading on the copy. You can then regulate the amount of grading by keyframing the opacity of the connected clip.
Mark Suszko
on Aug 19, 2016 at 3:08:45 pm
I like Fedor's approach, but wanted to add, you can also treat this problem in Apple Motion.
Noam Osband
on Sep 28, 2016 at 7:47:21 pm
Is it possible to do something like this with Color Finale?
