Replacing clip with Project or compound clip
Juan Lesta
on Jul 31, 2016 at 12:11:42 pm
Hi!
I'm trying to resolve this situation:
An editor (1) edited an interview and sent rendered it as a clip it to the editor 2
Editor 2 re-edited the interview with more clips and cuts, and sent it to me.
Now I have a project with a lot of references to the first edition which is a clip, but I have the project referenced to this clip.
The issue is: there is any way to replace the references to the clip with the project (or compound clip) which is referenced to?
Thanks a lot
Jeff Kirkland
Re: Replacing clip with Project or compound clip
on Aug 1, 2016 at 12:53:37 am
I'm not sure I 100% follow what you're needing to do but no, you can't relink or change the clip the edit references to.
What's the issue you're trying to solve?
(For some reason I can't edit my own posts so apologies in advance for the stupid mistakes and bad English that I can't go back and fix)
Jeff Kirkland | Video Producer & Cinematographer
Melbourne, Australia | Twitter: @jeffkirkland
Juan Lesta
on Aug 2, 2016 at 7:36:56 pm
Hi, and thanks.
I need to replace a clip with edited content with the project it comes from (and was done from).
I thinks its no possible :-(
