Workflow for adding photos
eric garten
on Jul 28, 2016 at 1:40:04 pm
First off I am a hack;
I've read through 2 instruction books,
subscribe to to online tutorials like Mac Pro video,
and have shamelessly lurked on your threads in the past,
enough to make a few music videos with multi cams.
I'm using 10.03 on an iMac with OS X 10.8.5
I'm doing a DVD for my landlady where she is interviewing her grandson.
so I made a multi cam clip from the two camera angles
and blended the mics on to that track.
she then wanted me to add a symphony from her grandfather, which worked well as a separate audio track,
and finally she wanted me to add gaps of a few seconds each in the multi-cam
and superimpose some family photos.
The audio and video and gaps all work great;
when I place the photos on top I want only them to be seen,
and of course right now they are merely composited on top of the multi cam.
if I do an overwrite edit, that solves the video problem, but i lose the audio from the multi-cam.
if I try to break apart the audio, the audio tab shows unsupported clip and grays out the option to detach.
Only workaround I stumbled upon, is to use blade edits to edit the multi cam clip at the edges of the photo
and then control V the underlying clips and reduce the opacity to zero,
which feels ultra amateur...
Doug Metz
Re: Workflow for adding photos
on Jul 28, 2016 at 7:57:11 pm
IMO, best option would be to fill the frame with the photos. Barring that, you could use a generator or a solid color still image as a matte...
Doug Metz
Anode
Brett Sherman
on Jul 28, 2016 at 9:54:00 pm
You can also add a solid black fill under the photos, but on top of the multicam clip. Go to Generators, select Custom Color. Drop into timeline.
Brett Sherman
One Man Band (If it's video related I'll do it!)
I work for an institution that probably does not want to be associated with my babblings here.
eric garten
on Jul 29, 2016 at 9:20:10 pm
yes, yes, of course; good catch!
thanx, fellas...
