Final Cut Pro Black bars slide out.
Jack Clark
on Jul 25, 2016 at 3:53:56 am
Hey guys,
This is probably a simple effect. Can someone tell me how to slide the black bars in like at the 13 second of this video without doing it manually?
J
Mark Suszko
Re: Final Cut Pro Black bars slide out.
on Jul 25, 2016 at 2:35:56 pm
Um, Crop using keyframing?
Jack Clark
on Jul 25, 2016 at 6:32:31 pm
Thanks that was simple :P
Bill Davis
on Jul 27, 2016 at 4:57:40 pm
It's actually not super simple the way they did it. The ballistics of the bar movements is a more sophisticated ease-in than just a standard wipe.
So you'll need to keyframe the bars using speed ramps if you want to precisely match what they did.
Pretty basic in Motion - and certainly possible directly in X, but probably a 5 to 10 minute build to set up. Once you do that, of course, you can copy and re-use it at will, but as always, nice things typically take time to create.
That or find a packaged wipe or effect with the speed ramps built in.
Good luck.
Creator of XinTwo - http://www.xintwo.com
The shortest path to FCP X mastery.
