Ken Burns Effect Over Zooming and Changing Position
Wesley Kelemen
on Jul 14, 2016 at 10:40:02 pm
To cut to the point.. I'm making a photo montage so I'm using the Ken Burns Effect.
Maybe there is a reason for this but why do I choose a start and end point and it over zooms. For instance I put the start point at the full frame of the image but once i click "done" it instantly zooms in maybe 10 - 25 percent. So I have to make the start point bigger than the frame itself by guessing just to have the start point at full frame.
It gets really tricky when I take two vertical images side by side, shrink them so they fit and then try and Ken Burns them. So the preview of the Ken Burns shows everything is perfect but when I click done zooms in 200 percent and moves the image around.
I want to be able to ken burns a vertical image and also be able to start a ken burns at full frame...
Can anyone give a suggestion or explain what is going on? Thanks a lot for your help. I thought taking a break from video and editing a photo montage would be an easy job...
