multicam question?
Mark Smith
multicam question?
on Jul 11, 2016 at 9:16:46 pm
I created a multicam clip and edited a cut, call that V.1
Got some notes from the director and made a snapshot of V.1 and started working the notes info into that cut.
Needed to add angle to the multicam of another take on a section of the video so with the angle editor I went back to the original multicam clip, added the needed angle.
Now when I work on the snapshot ( where I have already made a number of the required changes) the angle I add is not visible. I thought the change I made to the parent clip would ripple through but apparently not.
Is the correct procedure add the angle to the original v.1 cut , then make the snapshot v.1 with the added angle, and finally implement changes?
Noah Kadner
Re: multicam question?
on Jul 11, 2016 at 9:27:36 pm
Snapshots are the same as Save a copy or Save As- not interconnected at all.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Jeff Kirkland
on Jul 11, 2016 at 11:38:12 pm
Am I right in thinking that duplicating a project vs snapshotting it should have worked the way he expected though?
(For some reason I can't edit my own posts so apologies in advance for the stupid mistakes and bad English that I can't go back and fix)
Jeff Kirkland | Video Producer & Cinematographer
Melbourne, Australia | Twitter: @jeffkirkland
Craig Alan
on Jul 11, 2016 at 11:38:38 pm
What is the difference between an independent compound clip and a snapshot?
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
Jeff Kirkland
on Jul 11, 2016 at 11:52:59 pm
I'm assuming that the OP is talking about making a snapshot of a project vs a duplicate. I my understanding is right, a project duplicate will share charges made to things like compound clips, Multicam clips, etc but a project snapshot breaks those connections and stands alone.
Mark Smith
on Jul 12, 2016 at 12:25:38 am
Yes, I made a snapshot of the project then had to add in an new angle to the multicam clip. I went back to the original multicam clip added the angle, but the added angle did not appear in the snapshot version of the project.... But now I have bigger problems- see my new post.
