Do FCPX use files from the cache when exporting your videos?
Sergio Bianco
on Jun 24, 2016 at 2:21:01 pm
I am trying to make my system work more smoothly and I have learnt that one key is to keep files that are needed at the same time in different drives.
Now I have one external drive for media and libraries, and one for the cache. I usually export my final videos in the same drive I use for the cache, but I was wondering if adding a third drive could speed up the process. This would make sense if FCPX was actually using the files from your cache when exporting, but if it is starting from scratch it wouldn’t change anything. Hence the question.
Jeremy Garchow
Re: Do FCPX use files from the cache when exporting your videos?
on Jun 24, 2016 at 3:41:01 pm
If the Project is rendered, FCPX seems to use those files, yes, especially when exporting the same format (like ProRes render to ProRes export).
It would be easy to run a test of this. Move the cache, do the export with the Project rendered, then delete the cache, and redo the export with it unrendered and see which is faster.
Noah Kadner
on Jun 24, 2016 at 10:30:46 pm
Also performance rests mostly with the GPU, CPU and the specs of hard drives. Splitting up to a 3rd drive is not likely to make much impact and might even slow things down a bit.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
XinTwo - FCPX Training
Charlie Austin
on Jun 25, 2016 at 12:24:12 am
Media and Libraries should be on Separate drives if possible. It'll work fine if not, but X is constantly reading and writing to the Library, so having Media (and cache) on a different drive is ideal and you may get better performance. So adding a 3'rd (fast) Drive for cache couldn't hurt.
Like Jeremy said, if your Project is rendering to the same format as the export, X will use the cache files when it writes the master, speeding things up. If you export at a different format than the project is set, it has to do it from scratch.
~ My FCPX Babbling blog ~
~"It is a poor craftsman who blames his tools."~
~I still need to play Track Tetris sometimes. An old game that you can never win~
~"The function you just attempted is not yet implemented"~
Darren Roark
on Jun 25, 2016 at 2:33:42 am
Hello The Dude,
My setup is I keep my libraries on my internal SSD as it's the fastest drive I have, but I put my cache on an external 1TB SSD drive via Thunderbolt. My media is on a Promise R4 Thunderbolt RAID
I do a lot of optical flow and sometimes those analysis files can get huge and bog down the system while being made so keeping them off the system drive is helpful.
The main reason I would say to have footage playback on one drive and export projects to another drive is if the drives are single platter drives. In that case one will be reading and the other will be writing your export. In this case separate drives do help.
