FCP 7 Multiclip issue
Corey Carter
on Jun 13, 2016 at 2:50:52 pm
I am working with 2 Panasonic HDX 900 clips and 1 audio clip originally recorded on a atomos samurai capturing device. We edit the 900s in ProRes so we convert the audio files we get to ProRes in FCP7.
When making multiclips the first few work but when I get to the 3rd one and create it I get a "general error" when trying to play it back. Every spec of these clips are the same except for the Data rate. The 900s data rate is 12.7 and my audio (now converted to video file) is 2.0. As far as I can tell from what Ive read this should not affect my multiclip (especially because the other audio clips with the same data rate work in the multiclips).
Can anyone help?
Corey Carter
Re: FCP 7 Multiclip issue
on Jun 13, 2016 at 7:13:31 pm
Thank you but I don't see it. Can you be more specific?
John Rofrano
on Jun 14, 2016 at 9:37:07 pm
[Corey Carter] "Can you be more specific?"
He gave you a direct link to the Apple Final Cut Pro Legacy forum for all the "legacy" versions, 7, 6, 5, ... This is the Final Cut Pro X for for version X.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
