Export Video with Alpha Channel in FCPX?
Oscar Bucco
on May 26, 2016 at 6:40:03 pm
Hello, I have a interview on greenscreen and I keyed out the green. Client is requesting 32 bit movie with alpha channel. Is this possible in FCPX? How do I export movie with Alpha channel and also how to I export in 32 bit?
Many thanks
Jeremy Garchow
Re: Export Video with Alpha Channel in FCPX?
on May 27, 2016 at 2:01:57 am
32 bit most likely means 4:4:4:(4)
4x8 is "32bit". The forth four is the alpha channel.
Set your project render settings to ProRes 444 in the Project Settings (command-j) and share a master file with "same as source" settings in the codec.
Oscar Bucco
on May 27, 2016 at 4:25:46 am
Worked like a charm. Thank you!
