FCPX transitions changes color temperature midway
Elliot Lim
on May 25, 2016 at 9:47:03 pm
Hi there
Noticing that final cut transitions (fade to color and crossfade) are causing a shift in color temperature in the clips either midway or just as it starts. The image moves from a cool grade to a undesired warm grade.
Footage is from Sony Fs7, effects are default color correction and cold aura. Aggravating factor is that the clip also displays this behaviour even when the transition is moved as if it is hard coded into the footage itself.
Has anyone encountered this before? And what was your solution to it?
Noah Kadner
Re: FCPX transitions changes color temperature midway
on May 26, 2016 at 5:59:56 pm
In previews or final outputs?
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
Elliot Lim
on May 26, 2016 at 9:16:00 pm
Both in previews and outputs, which is the main reason why it is so perplexing. On an unrelated note, we are noticing random 'pixelation' effect on 4K footage from Fs7 as well. Again, seeming occurring either in middle or at the start/end of the transitions.
Darren Roark
on May 26, 2016 at 9:59:00 pm
This could be a shot in the dark but is it possible there is a codec/camera firmware mismatch?
What version of FCP X are you on?
You may want to manually reinstall the pro video formats https://support.apple.com/kb/DL1396?locale=en_US
Noah Kadner
on May 27, 2016 at 11:07:10 pm
Yep- would do full updates on the camera and the plugin.
Noah
Elliot Lim
on May 30, 2016 at 4:25:36 am
Did notice that ours is at 10.2.2 so will try again after update, thanks for the heads up.
