Sony FS 7 LUT
Robin S. Kurz
Sony FS 7 LUT
on May 25, 2016 at 3:35:37 pm
Would anyone possibly know of a source for a generic Sony FS 7 SLog to REC 709 LUT for download, for use in FCP? Cheers.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Michael Hancock
Re: Sony FS 7 LUT
on May 25, 2016 at 6:53:39 pm
You may be able to make your own:
https://cameramanben.github.io/LUTCalc/
Set the camera to FS7, your Rec Gamma and Gamut, then output Gamma and Gamut. Name your LUT, set the LUT type to FCPX and generate.
I don't have any FS7 footage to test it with, but below is an FS7 S-Log S-Gamut3.cine to Rec709 LUT I generated with it (3D 32x32x32 LUT). I also don't have a way to test it in FCPX right now so it may not work, or it may look awful. If you test it, let me know if it works.
https://www.dropbox.com/s/jsz6co9bwpiurba/Sony_FS7_SLog_to_Rec709.cube?dl=0
Michael Hancock
Editor
Robin S. Kurz
Re: Sony FS 7 LUT
on May 26, 2016 at 8:45:11 am
[Michael Hancock] "You may be able to make your own: https://cameramanben.github.io/LUTCalc/"
Day-um! That's a cool lookin' app! :-D Thanks for the heads up! I'll definitely have to check it out... especially at that ridiculous price.
[Michael Hancock] "If you test it, let me know if it works."
Wow, thanks! I'll give it a shot and let you know. Otherwise tool around myself also.
Cheers,
Robin
Robin S. Kurz
Re: Sony FS 7 LUT
on May 26, 2016 at 9:09:07 am
Just gave it a shot, and it looks great and, worst case, is definitely a great (i.e. much better) starting point. Thanks again!
- RK
Michael Hancock
Re: Sony FS 7 LUT
on May 26, 2016 at 3:19:19 pm
Glad it worked! And I highly recommend the LutCalc app. It's quite fantastic and ridiculously cheap.
Michael Hancock
Editor
