BMD driver 10.6.5 - still useless
Bret Williams
on May 4, 2016 at 5:19:55 pm
On my 2012 iMac with El Cap at least. Hard crash after a few minutes or even seconds of playback.
Jeremy Garchow
Re: BMD driver 10.6.5 - still useless
on May 4, 2016 at 6:20:03 pm
Same here on Yosemite.
Oliver Peters
on May 4, 2016 at 9:34:28 pm
10.6.4 on El Cap is running fine for me.
- Oliver
Orlando, FL
http://www.oliverpeters.com
Bret Williams
on May 24, 2016 at 1:22:53 am
10.6.6 seems cured. Been a light day but no crashes.
Jeremy Garchow
on May 24, 2016 at 1:30:38 am
Wow.
I had three crashes today, will now download 10.6.6 immediately!
Thanks for the update.
Bret Williams
on May 24, 2016 at 2:13:14 am
With prior versions I couldn't go 2 minutes. No joke. I bought an AJA it was so bad. And while the performance of the AJA us similar, the interface was horrible. And it often wouldn't let go of the app after you quit.
.I see in the BMD notes that it fixes some SDI bug. Out of curiosity how are you monitoring and what are you home up to? I'm using a Flanders LM series via SDI.
Good luck!
Jeremy Garchow
on May 24, 2016 at 2:19:11 am
SDI out to a patch panel, SDI to a few different monitors and devices.
Bret Williams
on May 24, 2016 at 2:20:26 am
I am my patch panel.
Jeremy Garchow
on May 24, 2016 at 4:10:13 am
so say we all, sir
Bret Williams
on May 24, 2016 at 2:13:33 pm
Never mind. F* me. Crashing out to decklink CMIO again. (plugs back in AJA)
Jeremy Garchow
on May 24, 2016 at 3:36:14 pm
So say it ain't so we all....sir.
