Proxy files used in MultiCam?
James Villeneuve
on Apr 29, 2016 at 5:25:37 pm
Hi ladies and gents.
Quick question. I am doing a project with some go pro and Sony A7S footage. I converted everything to proxy files and things are running smoothly. When I create a multicam clip, the background processes rev up and FCPX is transcoding the files in the Multicam.
So my question(s) is(are)... Why doesn't the multicam shot I created simply use the proxy files that I generated? Is this a setting I'm unaware of?
Is optimized multicam footage different from proxy files? Wha?
Thanks in advance!
James.
Robin S. Kurz
Re: Proxy files used in MultiCam?
on Apr 29, 2016 at 5:46:41 pm
One can only assume that it's transcoding as per the default preference setting:
Whether you're currently in proxy mode or not, with the default setting it will/should transcode for when you're in ORIGINAL mode either way.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
