FCP X Project (timeline) to FCP 7
Adam Berch
on Apr 12, 2016 at 3:00:07 pm
Is there a way to exporter a FCP X timeline or Project to FCP 7 without using X27?
Thanks in advance.
FCP X 10.2.2
FCP 7
Jeff Kirkland
Re: FCP X Project (timeline) to FCP 7
on Apr 12, 2016 at 8:23:11 pm
Resolve might do it via XML but Xto7 is your best bet. It's been a long while since I used Xto7, or XtoCC as it is now but keep in mind that any trip back to FCP 7 is going to be a dumbed down version of the project because 7 ain't that smart.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
Adam Berch
on Apr 12, 2016 at 8:43:51 pm
Thanks for the info. Here is what I am trying to do.
I have a 20 minute timeline in FCP 7, I exported it as an XML from FCP 7. I used 7toX and brought it into FCP X. I want to be able to do a color correction in FCP X, export it through XML back into FCP 7 where all of the color changes are still present that I did in FCP X.
How can I accomplish this? Please give me step by step instructions.
Thank You in advance.
Oliver Peters
on Apr 12, 2016 at 9:00:18 pm
[Adam Berch] " I want to be able to do a color correction in FCP X, export it through XML back into FCP 7 where all of the color changes are still present that I did in FCP X. "
Not possible. The color correction effects in X don't match those in 7, so there's no correlation between the two. You could render out a "flattened" master file from X and bring that back into 7 if you like. Then the color correction will be "baked" in.
- Oliver
Orlando, FL
http://www.oliverpeters.com
Doug Metz
on Apr 13, 2016 at 8:27:17 pm
As Oliver pointed out, the only way to do this is export video with baked-in correction. In some cases, you may also see a gamma shift when you bring your newly exported file(s) into 7.
I guess I'm wondering why you wouldn't simply finish the project in FCPX, now that you've got it in there...
Doug Metz
Anode
