trying to open a fcp 10.0 project in fcp 10.2.3
David Palmieri
on Apr 5, 2016 at 6:13:49 am
I have gotten as far as having all the raw footage files open up in fcp 10.2.3 but the timeline project is nowhere to be seen. I am apparently not using the update function properly. Please help.
This is what I have on the external drives.
Drive 1:
folder called "Final Cut Events"
inside that is a folder called "Craft 15"
inside that folder is 5 things:
folder "Backups"
file "CurrentVersion.fcpevent"
folder "Original Media"
folder "Render Files"
folder "Transcoded Media"
Drive 2:
folder called"Craft 15 copy"
in folder is 2 things:
folder "Backups"
file "CurrentVersion.fcpproject"
when I do the update all in fcp 10.2.3 everything seems to show up in the new library except for the project (timeline)
all the footage is there...just no timeline.
*** I also tried creating a folder on drive 1 called 'Final Cut Projects' and placed the project file in there. fop is not finding any projects. just the event raw footage.***
David
Russ Haskell
Re: trying to open a fcp 10.0 project in fcp 10.2.3
on Apr 5, 2016 at 2:04:13 pm
Is one of these drives your start-up? If it is, the Final Cut Projects folder needs to be in your Movies folder. Also, the entire sub-folder (Craft15 Copy) should be in the Final Cut Projects folder that you created – not just the project file.
Russ
David Palmieri
on Apr 5, 2016 at 2:26:33 pm
its not startup drive. to simplify, i created a new folder on drive 1 called "Final Cut Projects" and placed the project file in it. (so everything is now on 1 drive).
The folder Craft 15 copy only has the project file in it and a folder called backups with one backup file of that project file in it. thats it.
Charlie Austin
on Apr 7, 2016 at 4:02:48 pm
For pre 10.1 stuff, you should have 2 folders in the Folder you point X to for updating. A projects folder, and an events folder. Detail here, among other places...
~ My FCPX Babbling blog ~
~"It is a poor craftsman who blames his tools."~
~"The function you just attempted is not yet implemented"~
David Palmieri
on Apr 7, 2016 at 4:21:45 pm
yes, please see my last reply.
i have done that.
on the X drive i have 2 root directory folders with all the files in them:
Final Cut Events and Final Cut Projects.
its recognizing the stuff in the events folder. still not recognizing the project file.
Ronny Courtens
on Apr 7, 2016 at 8:27:53 pm
Hi David,
Let's go through this step by step, just to make sure that everything updates correctly.
On your X drive, create a new folder called "FCP X 10.0" and put the old Final Cut Projects and Final Cut Events folders inside this folder.
So, inside "FCP X 10.0" you should have two folders:
1. A folder called "Final Cut Events" with inside it a folder called "Craft 15".
In the "Craft 15" folder you need to have:
- a "Backups" folder
- a "CurrentVersion.fcpevent" file
- an "Original Media" folder
- a "Render Files" folder
- a "Transcoded Media" folder
2. A folder called "Final Cut Projects" with inside it a folder called "Craft 15".
In the "Craft 15" folder You need to have:
- a "CurrentVersion.fcpproject" file
If that's correct, launch FCP X and select File > Update Projects and Events".
The Update window will open. In the Update window, click the Locate button.
A Finder window will open. In the Finder window, go to your X drive and select the "FCP X 10.0" folder, then press the Update button.
FCP X will create a new Library from the old Final Cut Projects and Final Cut Events folders.
Under the Library icon you see a folder called "Smart Collections". Click on the little triangle to disclose the contents of this folder. Inside it you will see a Smart Collection called "Projects". Select it. Do you see any projects in the Browser now?
- Ronny
