Problem with a project exporting
Marinos Yiannakis
on Mar 30, 2016 at 6:50:02 pm
I finished a wedding editing and as i tried to export the last project it goes up to 37% and then stops. I exported just fine all the other 5 projects but the last one created this problem. I restarted the computer, i copied the project in to another project but the same problem occurred. Anyone came upon the same problem and what could be the solution?
Brian Thomas
Re: Problem with a project exporting
on Mar 31, 2016 at 12:58:28 pm
How about making a new project with just, say, the first half of the clips and see if that exports OK? If so then try another set of clips etc until you narrow down to where the problem might lie. Just an idea.
FCPX and PPro 6. iMac 24 + MBP 15". Near Geneva, Switzerland
Jeff Kirkland
on Apr 2, 2016 at 11:36:49 pm
Did you copy the project with or without the render files? Last time i had something like that happen, it was because of a corrupt render file.
And as has been suggested, if all else fails, try exporting segments and see if you can track down the faulty clip.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
